Hi,
I found on Internet a drawing to the Fokker D.24 piston engine
single seat low-wing fighter project,my dear Lark suggested that
project was given the Ontwerp designation number 192,can anyone
confirm about that?.
Hi,
this is actualy a D21 fichter
But as drawen with retractabole landing gear
Thank you J.weel,
but do you know its Ontwerp number ?.
This could be ontwerp 150, need to check some sources though
Thank you G-1reaper,
but I know the Ontwerp 150 was a developed version of D.XXI;
Hi Hesham,
Not quite. As far as I know the 'D.24', a June 1939 proposal, was to have a Bristol Perseus X engine, while Ontwerp 192 was probably very similar but was to have a Bristol Taurus.
J. Weel is quite correct that these were actually very similar to the D.21: minimum change derivatives to counter the Koolhoven FK.58, whereas the earlier Ontwerp 151 and 152 ('D.22') were new, more advanced designs.
Peter
Laatst gewijzigd door Fogg; 28 februari 2013 om 00:24
Thank you Fogg,
but has anyone a drawing to Ontwerp 192 ?.
Via Frits Gerdessen:
Het tekeningetje komt van een soort overzicht met globale zijaanzichten van D-typen.
De D.24 was de ultieme D.21. Een prestatieblad van de D.21 verscheen 3 dagen later als D.24.
De 150 en 151 hebben NIETS met de D.21 te maken.
De 152 was de T.VI, kruising tussen T.V en G.1.
Van 192 zijn geen tekeningen bekend. Wel is er geschetst op tekening 41651 van de 150. De motor (Taurus) is verder naar voren en heeft een kleinere diameter. Dat kan betekenen dat de 150 (Hercules) is gewijzigd voor de Taurus.
Hartelijke groet,
Jan Grisnich
Thank LVA-40,
and we know from P.150 up to P.160,I suspect in P.161,just my suggesting.
Again from ing. F. Gerdessen:
Project 161 is a reconaissance airplane, based on the Fokker C.X with Daimler Benz engine. No drawing is known. Please try to get an article of the Fokker Projects, written by F. Gerdessen in Air Enthusiast.
