Discussie: Lijst met afkortingen
    Standaard Lijst met afkortingen
    [h3]A [/h3]
    A Amber
    A/A Air-to-air
    AAL Above aerodrome level
    ABM Abeam
    ABT About
    ABV Above
    AC Altocumulus
    ACAS Airborne collision avoidance system
    ACC Area control centre or area control
    ACFT Aircraft
    ACK Acknowledge
    ACL Altimeter check location
    ACN Aircraft classification number
    ACPT Accept or accepted
    ACT Active or activated or activity
    AD Aerodrome
    ADA Advisory area
    ADC Aerodrome chart
    ADDN Addition or additional
    ADF Automatic direction-finding equipment
    ADJ Adjacent
    ADR Advisory route
    ADS Automatic dependent surveillance
    ADVS Advisory service
    ADZ Advise
    AFIL Flight plan filed in the air
    AFIS Aerodrome flight information service
    AFM Yes or affirm or affirmative or that is correct
    AFT After... (time or place)
    AFTN Aeronautical fixed telecommunication network
    A/G Air-to-ground
    AGA Aerodromes, air routes and ground aids
    AGL Above ground level
    AGN Again
    AIC Aeronautical information circular
    AIP Aeronautical information publication
    AIRAC Aeronautical information regulation and control
    AIREP Air-report
    AIRMET Information concerning en-route weather phenomena
    which may affect the safety of low-level aircraft operations
    AIS Aeronautical information services
    ALERFA Alert phase
    ALRS Alerting service
    ALS Approach lighting system
    ALT Altitude
    ALTN Alternate (aerodrome)
    AMA Area minimum altitude
    AMSL Above mean sea level
    ANC Aeronautical chart 1:500 000 (followed by name/title)
    ANCS Aeronautical navigation chart small scale (followed by name/title and scale)
    ANS Answer
    AOC Aerodrome obstacle chart (followed by type and name/title)
    AP Airport
    APAPI Abbreviated precision approach path indicator
    APCH Approach
    APDC Aircraft parking/docking chart (followed by name/title)
    APN Apron
    APP Approach control office or approach control or approach control service
    APR April
    APRX Approximate or approximately
    APSG After passing
    APV Approve or approved or approval
    ARC Area chart
    ARNG Arrange
    ARO Air traffic services reporting office
    ARP Aerodrome reference point
    ARR Arrive or arrival
    ARST Arresting (specify (part of) aircraft arresting equipment)
    AS Altostratus
    ASC Ascend to or ascending to
    ASDA Accelerate-stop distance available
    ASPEEDG Airspeed gain
    ASPEEDL Airspeed loss
    ASPH Asphalt
    AT At (followed by time at which weather change is forecast to occur)
    ATA Actual time of arrival
    ATC Air traffic control (in general)
    ATD Actual time of departure
    ATFM Air traffic flow management
    ATIS Automatic terminal information service
    ATM Air traffic management
    ATP At... (time or place)
    ATS Air traffic services
    ATTN Attention
    AT-VASIS Abbreviated T visual approach slope indicator system
    ATZ Aerodrome traffic zone
    AUG August
    AUTH Authorized or authorization
    AUW All up weight
    AUX Auxiliary
    AVBL Available or availability
    AVG Average
    AVGAS Aviation gasoline
    AWTA Advise at what time able
    AWY Airway
    AZM Azimuth
    [h3]B[/h3]
    B Blue
    BA Braking action
    BASE Cloud base
    BCFG Fog patches
    BCN Beacon (aeronautical ground light)
    BCST Broadcast
    BDRY Boundary
    BECMG Becoming
    BFR Before
    BKN Broken
    BL Blowing (followed by DU = dust, SA = sand or SN = snow)
    BLDG Building
    BLO Below clouds
    BLW Below
    BR Mist
    BRF Short (used to indicate the type of approach desired or required)
    BRG Bearing
    BRKG Breaking
    BTL Between layers
    BTN Between
    [h3]C[/h3]
    C Centre (preceded by runway designation number to identify a parallel runway)
    C Degrees Celsius (Centigrade)
    CAT Category
    CAT Clear air turbulence
    CAVOK Visibility, cloud and present weather better than prescribed values or conditions
    CB Cumulonimbus
    CC Cirrocumulus
    CCA (or CCB, CCC. .. etc., in sequence) Corrected meteorological message
    CD Candela
    CDN Coordination (message type designator)
    CF Change frequency to . . .
    CFM Confirm or I confirm
    CGL Circling guidance light(s)
    CH Channel
    CHG Modification (message type designator)
    CI Cirrus
    CIT Near or over large towns
    CIV Civil
    CK Check
    CL Centre line
    CLA Clear type of ice formation
    CLBR Calibration
    CLD Cloud
    CLG Calling
    CLIMB-OUT Climb-out area
    CLR Clear(s) or cleared to or clearance
    CLRD Runway(s) cleared (used in METAR/SPECI)
    CLSD Close or closed or closing
    CM Centimetre
    CMB Climb to or climbing to
    CMPL Completion or completed or complete
    CNL Cancel or cancelled
    CNL Flight plan cancellation
    CNS Communications, navigation and surveillance
    COM Communications
    CONC Concrete
    COND Condition
    CONS Continuous
    CONST Construction or constructed
    CONT Continue(s) or continued
    COOR Coordinate or coordination
    COORD Coordinates
    COP Change-over point
    COR Correct or correction or corrected
    COT At the coast
    COV Cover or covered or covering
    CPDLC Controller-pilot data link communications
    CPL Current flight plan
    CRC Cyclic redundancy check
    CRZ [wiki]kruissnelheid|Cruise[/wiki]
    CS [wiki]Call sign[/wiki]
    CS Cirrostratus
    CTA Control area
    CTAM Climb to and maintain
    CTC Contact
    CTL Control
    CTN Caution
    CTR Control zone
    CU Cumulus
    CUF Cumuliform
    CVR [wiki]Cockpit voice recorder[/wiki]
    CW Continuous wave
    CWY Clearway
    [h3]D[/h3]
    D Downward (tendency in RVR during previous 10 minutes)
    D Danger area (followed by identification)
    DA Decision altitude
    D-ATIS Data link automatic terminal information service
    DCKG Docking
    DCP Datum crossing point
    DCPC Direct controller-pilot communications
    DCT Direct (in relation to flight plan clearances and type of approach)
    DEC December
    DEC Degrees
    DEP Depart or departure
    DEP Departure
    DES Descend to or descending to
    DEST Destination
    DETRESFA Distress phase
    DEV Deviation or deviating
    DFDR Digital flight data recorder
    DFTI Distance from touchdown indicator
    DH Decision height
    DIP Diffuse
    DIST Distance
    DIV Divert or diverting
    DLA Delay or delayed
    DLY Daily
    DME Distance measuring equipment
    DNG Danger or dangerous
    DOM Domestic
    DP Dew point temperature
    DPT Depth
    DR Dead reckoning
    DR Low drifting (followed by DU = dust, SA =sand or SN = snow)
    DRG During
    DS Duststorm
    DTAM Descend to and maintain
    DTG Date-time group
    DTHR Displaced runway threshold
    DTRT Deteriorate or deteriorating
    DTW Dual tandem wheels
    DU Dust
    DUC Dense upper cloud
    DUPE This is a duplicate message
    DUR Duration
    D-VOLMET Data link VOLMET
    DVOR Doppler VOR
    DW Dual wheels
    DZ Drizzle
    [h3]E[/h3]
    E East or eastern longitude
    EAT Expected approach time
    EB Eastbound
    EDA Elevation differential area
    EEE# Error
    EET Estimated elapsed time
    EFC Expect further clearance
    EGNOS European geostationary navigation overlay service
    EHF Extremely high frequency [30 000 to 300 000 MHz]
    ELBA Emergency location beacon aircraft
    ELEV Elevation
    ELR Extra long range
    ELT Emergency locator transmitter
    EM Emission
    EMBD Embedded in a layer (to indicate cumulonimbus embedded in layers of other clouds)
    EMERG Emergency
    END Stop-end (related to RVR)
    ENE East-north-east
    ENG Engine
    ENR En route
    ENRC En-route chart (followed by name/title)
    EOBT Estimated off-block time
    EQPT Equipment
    ER* Here . . . or herewith
    ESE East-south-east
    EST Estimate or estimated or estimation
    ETA Estimated time of arrival or estimating arrival
    ETD Estimated time of departure or estimating departure
    ETO Estimated time over significant point
    EV Every
    EXC Except
    EXER Exercises or exercising or to exercise
    EXP Expect or expected or expecting
    EXTD Extend or extending
    [h3]F[/h3]
    F Fixed
    FAC Facilities
    FAF Final approach fix
    FAL Facilitation of international airtransport
    FAP Final approach point
    FATO Final approach and take-off area
    FAX Facsimile transmission
    FBL Light (used to indicate the intensity of-weather phenomena, interference or static reports, e.g. FBL RA = light rain)
    FC Funnel cloud (tornado or water spout)
    FCST Forecast
    FCT Friction coefficient
    FDPS Flight data processing system
    FEB February
    FEW Few
    FG Fog
    FIC Flight information centre
    FIR Flight information region
    FIS Flight information service
    FISA Automated flight information service
    FL Flight level
    FLD Field
    FLG Flashing
    FLR Flares
    FLT Flight
    FLTCK Flight check
    FLUC Fluctuating or fluctuation or fluctuated
    FLW Follow(s) or following
    FLY Fly or flying
    FM From
    FM From (followed by time weather change is forecast to begin)
    FMS Flight management system
    FMU Flow management unit
    FNA Final approach
    FPAP Flight path alignment point
    FPL Filed flight plan
    FPM Feet per minute
    FPR Flight plan route
    FR Fuel remaining
    FREQ Frequency
    FRI Friday
    FRNG Firing
    FRONT Front (relating to weather)
    FRQ Frequent
    FSL Full stop landing
    FSS Flight service station
    FST First
    FT [wiki]voet|Feet[/wiki] (dimensional unit)
    FTP Fictitious threshold point
    FU Smoke
    FZ Freezing
    FZDZ Freezing drizzle
    FZFG Freezing fog
    FZRA Freezing rain
    [h3]G[/h3]
    G Green
    G Variations from the mean wind speed (gusts) (followed by figures in METAR/SPECI and TAP)
    GA Go ahead, resume sending
    G/A Ground-to-air
    G/A/G Ground-to-air and air-to-ground
    GAGAN GPS and geostationary earth orbit augmented navigation
    GAMET Area forecast for low-level flights
    GARP GBAS azimuth reference point
    GBAS Ground-based augmentation system
    GCAJ Ground controlled approach system or ground controlled approach
    GEN General
    GEO Geographic or true
    GES Ground earth station
    GLD [wiki]zweefvliegtuig|Glider[/wiki]
    GLONASS Global orbiting navigation satellite system
    GMC . . . Ground movement chart (followed by name/title)
    GND Ground
    GNDCK Ground check
    GNSS Global navigation satellite system
    GP Glide path
    GPS Global positioning system
    GR Hail
    GRAS Ground-based regional augmentation system
    GRASS Grass landing area
    GRIB Processed meteorological data in the form of grid point values expressed in binary form
    GRVL Gravel
    GS [wiki]grondsnelheid|Ground speed[/wiki]
    GS Small hail and/or snow pellets
    GUND Geoid undulation
    [h3]H[/h3]
    H High pressure area or the centre of high pressure
    H24 Continuous day and night service
    HAPI Helicopter approach path indicator
    HBN Hazard beacon
    HDF High frequency direction-finding station
    HDG Heading
    HEL [wiki]Helikopter|Helicopter[/wiki]
    HF High frequency [3 000 to 30 000 kHz]
    HOT Height or height above
    HJ Sunrise to sunset
    HLDG Holding
    HN Sunset to sunrise
    HO Service available to meet operational requirements
    HOL Holiday
    HOSP Hospital aircraft
    HPA Hectopascal
    HR Hours
    HS Service available during hours of scheduled operations
    HURCN Hurricane
    HVDF High and very high frequency direction finding Stations (at the same location)
    HVY Heavy
    HVY Heavy (used to indicate the intensity of weather phenomena, e.g. HVY RA = heavy rain)
    HX No specific working hours
    HYR Higher
    HZ Haze
    HZ Hertz (cycle per second)
    [h3]I[/h3]
    IAC Instrument approach chart (followed by name/title)
    IAF Initial approach fix
    IAO In and out of clouds
    IAP Instrument approach procedure
    IAR Intersection of air routes
    IAS Indicated airspeed
    IBN Identification beacon
    IC Ice crystals (very small ice crystals in suspension, also known as diamond dust)
    ICE Icing
    ID Identifier or identify
    IDENT Identification
    IF Intermediate approach fix
    IFF [wiki]IFF|Identification friend/foe[/wiki]
    IFR [wiki]Instrument flight rules[/wiki]
    IGA International general aviation
    ILS [wiki]Instrument landing system[/wiki]
    IM Inner marker
    IMC Instrument meteorological conditions
    IMPR Improve or improving
    IMT Immediate or immediately
    INA Initial approach
    INBD Inbound
    INC In cloud
    INCERFA Uncertainty phase
    INFO Information
    INOP Inoperative
    INP If not possible
    INPR In progress
    INS Inertial navigation system
    INSTL Install or installed or installation
    INSTR Instrument
    INT Intersection
    INTL International
    INTRG Interrogator
    INTRP Interrupt or interruption or interrupted
    INTSF Intensify or intensifying
    INTST Intensity
    IR Ice on runway
    ISA International standard atmosphere
    ISOL Isolated
    [h3]J[/h3]
    JAN January
    JTST Jet stream
    JUL July
    JUN June
    [h3]K[/h3]
    KG Kilograms
    KHZ Kilohertz
    KM Kilometres
    KMH Kilometres per hour
    KPA Kilopascal
    KT [wiki]knoop|Knots[/wiki]
    KW Kilowatts
    [h3]L[/h3]
    L Left (preceded by runway designation number to identify a parallel runway)
    L Locator (see LM, LO )
    L Low pressure area or the centre of low pressure
    LAN Inland
    LAT Latitude
    LDA Landing distance available
    LDAH Landing distance available, helicopter
    LDG Landing
    LDI Landing direction indicator
    LEN Length
    LF Low frequency [30 to 300 kHz]
    LGT Light or lighting
    LGTD Lighted
    LIH Light intensity high
    LIL Light intensity low
    LIM Light intensity medium
    LLZ Localizer
    LM Locator, middle
    LMT Local mean time
    LNG Long (used to indicate the type of approach desired or required)
    LO Locator, outer
    LOG Local or locally or location or located
    LONG Longitude
    LORAN LORAN (long range air navigation system)
    LRG Long range
    LTD Limited
    LTP Landing threshold point
    LV Light and variable (relating to wind)
    LVE Leave or leaving
    LVL Level
    LYR Layer or layered
    [h3]M[/h3]
    M [wiki]Mach|Mach number[/wiki] (followed by figures)
    M Metres (preceded by figures)
    M Minimum value of runway visual range (followed by figures in METAR/SPECI)
    MAA Maximum authorized altitude
    MAG Magnetic
    MAINT Maintenance
    MAP Aeronautical maps and charts
    MAPT Missed approach point
    MAR At sea
    MAR March
    MAX Maximum
    MAY May
    MBST Microburst
    MCA Minimum crossing altitude
    MCW Modulated continuous wave
    MDA Minimum descent altitude
    MDF Medium frequency direction-finding station
    MDH Minimum descent height
    MEA Minimum en-route altitude
    MEHT Minimum eye height over threshold (for visual approach slope indicator systems)
    MET Meteorological or meteorology
    METAR Aerodrome routine meteorological report (in meteorological code)
    MET REPORT Local routine meteorological report (in abbreviated plain language)
    MF Medium frequency [300 to 3 000 kHz]
    MHDF Medium and high frequency direction-finding stations (at the same location)
    MHVDF Medium, high and very high frequency direction-finding stations (at the same location)
    MHZ Megahertz
    MID Mid-point (related to R VR)
    MIFG Shallow fog
    MIL Military
    MIN Minutes
    MKR Marker radio beacon
    MLS Microwave landing system
    MM Middle marker
    MNM Minimum
    MNPS Minimum navigation performance specifications
    MNT Monitor or monitoring or monitored
    MNTN Maintain
    MOA Military operating area
    MOC Minimum obstacle clearance (required)
    MOD Moderate (used to indicate the intensity of weather phenomena, interference or static reports, e.g. MODRA = moderate rain)
    MON Above mountains
    MON Monday
    MOPS Minimum operational performance standards
    MOV Move or moving or movement
    MPS Metres per second
    MRA Minimum reception altitude
    MRG Medium range
    MRP ATS/MET reporting point
    MS Minus
    MSA Minimum sector altitude
    MSAS Multifunctional transport satellite (MTSAT) satellite-based augmentation system
    MSAW Minimum safe altitude warning
    MSG Message
    MSL Mean sea level
    MSSR Monopulse secondary surveillance radar
    MT Mountain
    MTU Metric units
    MTW Mountain waves
    MVDF Medium and very high frequency direction finding stations (at the same location)
    MX Mixed type of ice formation (white and clear)
    [h3]N[/h3]
    N No distinct tendency (in RVR during previous 10 minutes)
    N North or northern latitude
    NASC National AIS system centre
    NAT North Atlantic
    NAV Navigation
    NB Northbound
    NBFR Not before
    NC No change
    NCD No cloud detected (used in automated METAR/SPECI)
    NDB Non-directional radio beacon
    NDV No directional variations available (used in automated METAR/SPECI)
    NE North-east
    NEB North-eastbound
    NEG No or negative or permission not granted or that is not correct
    NGT Night
    NIL None or I have nothing to send to you
    NM [wiki]mijl|Nautical miles[/wiki]
    NML Normal
    NNE North-north-east
    NNW North-north-west
    NOF International NOTAM office
    NOSIG No significant change (used in trend-type landing forecasts)
    NOTAM A notice distributed by means of telecommunication containing information concerning the establishment, condition or change in any aeronautical facility, service, procedure or hazard, the timely knowledge of which is essential to personnel concerned with flight operations
    NOV November
    NOZ Normal operating zone
    NR Number
    NRH No reply heard
    NS Nimbostratus
    NSC Nil significant cloud
    NSW Nil significant weather
    NTL National
    NTZ No transgression zone
    NW North-west
    NWB North-westbound
    NXT Next
    [h3]O[/h3]
    OAC Oceanic area control centre
    OAS Obstacle assessment surface
    OBS Observe or observed or observation
    OBSC Obscure or obscured or obscuring
    OBST Obstacle
    OCA Obstacle clearance altitude
    OCA Oceanic control area
    OCC Occulting (light)
    OCH Obstacle clearance height
    OCNL Occasional or occasionally
    OCS Obstacle clearance surface
    OCT October
    OFZ Obstacle free zone
    OGN Originate
    OHD Overhead
    OM Outer marker
    OPA Opaque, white type of ice formation
    OPC Control indicated is operational control
    OPMET Operational meteorological (information)
    OPN Open or opening or opened
    OPR Operator or operate or operative or operating or operational
    OPS Operations
    O/R On request
    ORD Order
    OSV Ocean station vessel
    OTLK Outlook (used in SIGMET messages for volcanic ash and tropical cyclones)
    OTP On top
    OTS Organized track system
    OUBD Outbound
    OVC Overcast
    [h3]P[/h3]
    P Maximum value of wind speed or runway visual range (followed by figures in METAR/SPECI and TAP)
    P Prohibited area (followed by identification)
    PA Precision approach
    PALS Precision approach lighting system
    PANS Procedures for air navigation services
    PAPI Precision approach path indicator
    PAR Precision approach radar
    PARL Parallel
    PATC Precision approach terrain chart (followed by name/title)
    PAX Passenger(s)
    PCD Proceed or proceeding
    PCL Pilot-controlled lighting
    PCN Pavement classification number
    PDC Pre-departure clearance
    PDG Procedure design gradient
    PER Performance
    PERM Permanent
    PIB Pre-flight information bulletin
    PJE Parachute jumping exercise
    PL Ice pellets
    PLA Practice low approach
    PLN Flight plan
    PLVL Present level
    PN Prior notice required
    PNR Point of no return
    PO Dust/sand whirls (dust devils)
    POB Persons on board
    POSS Possible
    PPI Plan position indicator
    PPR Prior permission required
    PPSN Present position
    PRFG Aerodrome partially covered by fog
    PRI Primary
    PRKG Parking
    PROB Probability
    PROC Procedure
    PROV Provisional
    PS Plus
    PSG Passing
    PSN Position
    PSR Primary surveillance radar
    PSYS Pressure system(s)
    PTN Procedure turn
    PTS Polar track structure
    PWR Power
    [h3]Q[/h3]
    QDL Do you intend to ask me for a series of bearings? or I intend to ask you for a series of bearings (to be used in radiotelegraphy as a Q Code)
    QDM Magnetic heading (zero wind)
    QDR Magnetic bearing
    QFE Atmospheric pressure at aerodrome elevation (or at runway threshold)
    QFU Magnetic orientation of runway
    QGE What is my distance to your station? or Your distance to my station is (distance figures and units) (to be used in radiotelegraphy as a Q Code)
    QNH Altimeter sub-scale setting to obtain elevation when on the ground
    QTE True bearing
    QTF Will you give me the position of my station according to the bearings taken by the D/F stations which you control? or The position of your station according to the bearings taken by the D/F stations that I control was. . . latitude . . . longitude (or other indication of position), class . . . a t . . . hours (to be used in radiotelegraphy as a Q Code)
    QUAD Quadrant
    QUJ Will you indicate the TRUE track to reach you? Or The TRUE track to reach me is ... degrees a t . . hours (to be used in radiotelegraphy as a Q Code)
    [h3]R[/h3]
    R Right (preceded by runway designation number to identify a parallel runway)
    R Red
    R Restricted area (followed by identification)
    R Runway visual range (followed by figures in METAR/SPECI)
    RA Rain
    RAC Rules of the air and air traffic services
    RAG Ragged
    RAG Runway arresting gear
    RAI Runway alignment indicator
    RAIM Receiver autonomous integrity monitoring
    RASC Regional AIS system centre
    RASS Remote altimeter setting source
    RB Rescue boat
    RCA Reach cruising altitude
    RCC Rescue coordination centre
    RCF Radiocommunication failure (message type designator)
    RCH Reach or reaching
    RCL Runway centre line
    RCLL Runway centre line light(s)
    RCLR Recleared
    RDH Reference datum height
    RDL Radial
    RDO Radio
    RE Recent (used to qualify weather phenomena, e.g. RERA = recent rain)
    REC Receive or receiver
    REDL Runway edge light(s)
    REF Reference to . . . or refer to ...
    REG Registration
    RENL Runway end light(s)
    REP Report or reporting or reporting point
    REQ Request or requested
    RERTE Re-route
    RESA Runway end safety area
    RG Range (lights)
    RHC Right-hand circuit
    RIF Reclearance in flight
    RITE Right (direction of turn)
    RL Report leaving
    RLA Relay to
    RLCE Request level change en route
    RLLS Runway lead-in lighting system
    RLNA Request level not available
    RMAC Radar minimum altitude chart
    RMK Remark
    RNAV Area navigation
    RNG Radio range
    RNP Required navigation performance
    ROC Rate of climb
    ROD Rate of descent
    ROFOR Route forecast (in meteorological code)
    RON Receiving only
    RPI Radar position indicator
    RPL Repetitive flight plan
    RPLC Replace or replaced
    RPS Radar position symbol
    RQMNTS Requirements
    RQP Request flight plan
    RQS Request supplementary flight plan (message type designator)
    RR Report reaching
    RRA (or RRB, RRC... etc., in sequence) Delayed meteorological message (message type designator)
    RSC Rescue sub-centre
    RSCD Runway surface condition
    RSP Responder beacon
    RSR En-route surveillance radar
    RTD Delayed (used to indicate delayed meteorological message; message type designator)
    RTE Route
    RTF Radiotelephone
    RTG Radiotelegraph
    RTHL Runway threshold light(s)
    RTN Return or returned or returning
    RTODAH Rejected take-off distance available, helicopter
    RTS Return to service
    RTT Radioteletypewriter
    RTZL Runway touchdown zone light(s)
    RUT Standard regional route transmitting frequencies
    RV Rescue vessel
    RVR Runway visual range
    RVSM Reduced vertical separation minimum (300 m (1 000 ft)) between FL 290 and FL 410
    RWY [wiki]startbaan|Runway[/wiki]
    [h3]S[/h3]
    S State of the sea (followed by figures in METAR/SPECI)
    S South or southern latitude
    SA Sand
    SALS Simple approach lighting system
    SAN Sanitary
    ASAP As soon as possible
    SAR [wiki]Search and rescue [/wiki]
    SARPS Standards and Recommended Practices [ICAO]
    SAT Saturday
    SATCOM Satellite communication
    SB Southbound
    SBAS Satellite-based augmentation system
    SC Stratocumulus
    SCT Scattered
    SDBY Stand by
    SE South-east
    SEA Sea (used in connection with sea-surface temperature and state of the sea)
    SEB South-eastbound
    SEC Seconds
    SECN Section
    SECT Sector
    SELCAL Selective calling system
    SEP September
    SER Service or servicing or served
    SEV Severe (used e.g. to qualify icing and turbulence reports)
    SFC Surface
    SG Snow grains
    SGL Signal
    SH ... Shower (followed by RA = rain, SN = snow, PL = ice pellets, GR = hail, GS = small hail and/or snow pellets or combinations thereof, e.g. SHRASN = showers of rain and snow)
    SHF Super high frequency [3 000 to 30 000 MHz]
    SID Standard instrument departure
    SIF Selective identification feature
    SIG Significant
    SIGMET Information concerning en-route weather phenomena which may affect the safety of aircraft operations
    SIMUL Simultaneous or simultaneously
    SKC Sky clear
    SKED Schedule or scheduled
    SLP Speed limiting point
    SLW Slow
    SMC Surface movement control
    SMR Surface movement radar
    SN Snow
    SNOCLO Aerodrome closed due to snow (used in METAR/SPECI)
    SNOWTAM Special series NOTAM notifying the presence or removal of hazardous conditions due to snow, ice, slush or standing water associated with snow, slush and ice on the movement area, by means of a specific format
    SPECI Aerodrome special meteorological report (in meteorological code)
    SPECIAL Local special meteorological report (in abbreviated plain language)
    SPL Supplementary flight plan (message type designator)
    SPOC SAR point of contact
    SPOT Spot wind
    SQ Squall
    SQL Squall line
    SR Sunrise
    SRA Surveillance radar approach
    SRE Surveillance radar element of precision approach radar system
    SRG Short range
    SRR Search and rescue region
    SRY Secondary
    SS Sandstorm
    SS Sunset
    SSE South-south-east
    SSR Secondary surveillance radar
    SST Supersonic transport
    SSW South-south-west
    ST Stratus
    STA Straight-in approach
    STAR Standard instrument arrival
    STD Standard
    STF Stratiform
    STN Station
    STNR Stationary
    STOL [wiki]Short take-off and landing[/wiki]
    STS Status
    STWL Stopway light(s)
    SUBJ Subject to
    SUN Sunday
    SUP Supplement (AIP Supplement)
    SUPPS Regional supplementary procedures Service message
    SVCBL Serviceable
    SW South-west
    SWB South-westbound
    SWY Stopway
    [h3]T[/h3]
    T Temperature
    TA Transition altitude
    TAA Terminal arrival altitude
    TACAN UHF tactical air navigation aid
    TAF Aerodrome forecast (in meteorological code)
    TAIL [wiki]staartwind|Tail wind[/wiki]
    TAR Terminal area surveillance radar
    TAS [wiki]luchtsnelheid|True airspeed[/wiki]
    TAX Taxiing or taxi
    TC Tropical cyclone
    TCAC Tropical cyclone advisory centre
    TCAS Traffic Collision Avoidance System
    TCU Towering cumulus
    TDO Tornado
    TDZ Touchdown zone
    TECR Technical reason
    TEL Telephone
    TEMPO Temporary or temporarily
    TFC Traffic
    TGL [wiki]Touch-and-go[/wiki] landing
    TGS Taxiing guidance system
    THR Threshold
    THRU Through
    THU Thursday
    TIBA Traffic information broadcast by aircraft
    TIL Until
    TIP Until past... (place)
    TKOF Take-off
    TL . . . Till (followed by time by which weather change is forecast to end)
    TLOF Touchdown and lift-off area
    TMA Terminal control area
    TN . . . Minimum temperature (followed by figures in TAP)
    TNA Turn altitude
    TNH Turn height
    TO ... To ... (place)
    TOC Top of climb
    TODA Take-off distance available
    TODAH Take-off distance available, helicopter
    TOP Cloud top
    TORA Take-off run available
    TP Turning point
    TR Track
    TRA Temporary reserved airspace
    TRANS Transmits or transmitter
    TREND Trend forecast
    TRL Transition level
    TROP Tropopause
    TS Thunderstorm (in aerodrome reports and forecasts, TS used alone means thunder heard but no precipitation at the aerodrome)
    TS ... Thunderstorm (followed by RA= rain, SN = snow, PL = ice pellets, GR = hail, GS = small hail and/or snow pellets or combinations thereof, e.g. TSRASN = thunderstorm with rain and snow)
    TUE Tuesday
    TURB [wiki]turbulentie|Turbulence[/wiki]
    T-VASIS T visual approach slope indicator system
    TVOR Terminal VOR
    TWR Aerodrome control tower or aerodrome control
    TWY Taxiway
    TWYL Taxiway-link
    TX... Maximum temperature (followed by figures in TAP)
    TXT Text
    TYP Type of aircraft
    TYPH Typhoon
    [h3]U[/h3]
    U Upward (tendency in RVR during previous 10 minutes)
    UAB Until advised by . .
    UAC Upper area control centre
    UAR Upper air route
    UDF Ultra high frequency direction-finding station
    UFN Until further notice
    UHDT Unable higher due traffic
    UHF Ultra high frequency [300 to 3 000 MHz]
    UIC Upper information centre
    UIR Upper flight information region
    ULR Ultra long range
    UNA Unable
    UNAP Unable to approve
    UNL Unlimited
    UNREL Unreliable
    UP Unidentified precipitation (used in automated METAR/SPECI)
    U/S Unserviceable
    UTA Upper control area
    UTC Coordinated Universal Time
    [h3]V[/h3]
    V Variations from the mean wind direction (preceded and followed by figures in METAR/SPECI, e.g. 350V070)
    VA Volcanic ash
    VAAC Volcanic ash advisory centre
    VAC Visual approach chart (followed by name/title)
    VAL In valleys
    VAN Runway control van
    VAR Magnetic variation
    VAR Visual-aural radio range
    VASIS Visual approach slope indicator systems
    VC... Vicinity of the aerodrome (followed by FG =fog, FC = funnel cloud, SH = shower, PO = dust/sand whirls, BLDU = blowing dust, BLSA = blowing sand, BLSN = blowing snow, DS = duststorm, SS = sandstorm, TS = thunderstorm or VA = volcanic ash, e.g. VCFG = vicinity fog)
    VCY Vicinity
    VDF Very high frequency direction-finding station
    VER Vertical
    VFR [wiki]Visual flight rules[/wiki]
    VHF Very high frequency [30 to 300 MHz]
    VIP Very important person
    VIS Visibility
    VLF Very low frequency [3 to 30 kHz]
    VLR Very long range
    VMC Visual meteorological conditions
    VOLMET Meteorological information for aircraft in flight
    VOR VHF omnidirectional radio range
    VORTAC VOR and TACAN combination
    VPA Vertical path angle
    VRB Variable
    VSA By visual reference to the ground
    VSP Vertical speed
    VTOL [wiki]Vertical take-off and landing[/wiki]
    VV... Vertical visibility (followed by figures in METAR/SPECI and TAP)
    [h3]W[/h3]
    W West or western longitude
    W White
    W Sea-surface temperature (followed by figures in METAR/SPECI)
    WAAS Wide area augmentation system
    WAC World Aeronautical Chart ICAO 1:1 000 000 (folio-wed by name/title)
    WAFC World area forecast centre
    WB Westbound
    WBAR Wing bar lights
    WDI Wind direction indicator
    WDSPR Widespread
    WED Wednesday lasagna day
    WEF With effect from or effective from
    WGS-84 World Geodetic System 1984
    WI Within
    WID Width
    WIE With immediate effect or effective immediately
    WILCO Will comply
    WIND Wind
    WINTEM Forecast upper wind and temperature for aviation
    WIP Work in progress
    WKN Weaken or weakening
    WNW West-north-west
    WO Without
    WPT Way-point
    WRNG Warning
    WS Wind shear
    WSPD Wind speed
    WSW West-south-west
    WT Weight
    WTSPT Waterspout
    WWW Worldwide Web
    WX Weather
    [h3]X[/h3]
    X Cross
    XBAR Crossbar (of approach lighting system)
    XNG Crossing
    XS Atmospherics
    [h3]Y[/h3]
    Y Yellow
    YCZ Yellow caution zone (runway lighting)
    YR Your
    [h3]Z[/h3]
    Z(ulu) Coordinated Universal Time (in meteorological messages)
    Laatst gewijzigd door ReneL; 28 oktober 2008 om 14:45
